Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cobalt
Climate Control
Heater
Not Working
Heater blowing out cold air
2009 CHEVROLET COBALT
123,232 MILES
NESHA111
MEMBER
1 POST
My heat stop working when you turn the heat on it is blowing out cold air.
Jan 16, 2019 at 10:03 PM
Experienced Mechanic
Good morning,
Make sure you check your coolant level. Also, is the engine running at normal operating temperature? A bad thermostat could cause this.
https://www.2carpros.com/articles/car-heater-not-working
When you command heat and cool, can you hear the mode door move in the dash?
Under the hood, the heater hoses, if you feel them, are they both hot?
Jan 17, 2019 at 1:37 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
