Heat
160,000 MILES • 2WD • AUTOMATIC
TULPA
  • 53 POSTS
The A/C heater door blend actuator went bad so I got a replacement from auto zone. The guy was not sure which model I needed so I bought both, planned to take whichever one did not work back. After I replaced it, I checked the heater and it was blowing hot air. The temperature gauge however never moved even after driving it. And now it is no longer blowing hot air. I am a little confused, did I use the wrong one perhaps? And why would it have any effect on the thermostat?
Nov 20, 2017 at 7:49 AM
  • 110,248 POSTS
It should not have affected the thermostat. However, they do go bad. As far as no heat again, make sure the coolant level is full. If the needle does not move at all, I question a coolant sensor issue because even without the thermostat, the engine will heat to a certain point. At least, it will heat so you notice a difference in the air flow temperature. First, make sure there is coolant. If there is, run the vehicle with the heat on high. Then, feel both heater core hoses. Both should be hot. If they are, I would say the new part has failed. If only one is hot, there is no flow through the heater core.
Nov 20, 2017 at 9:27 AM
TULPA
  • 53 POSTS
I tried the other one i bought, I noticed a small difference in the two, first one I put in was the wrong one. So now the heat works but when I switch it to A/C it still blows hot air. Also, the temperature gauge only moves a little even after driving around. Even dropped for a minute. Does that still sound like a coolant sensor?
Nov 21, 2017 at 8:39 AM
