No heat when engine is running
162,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CCORCHADO
it will not give heat especially when is running. already replaced water pump , flush heater coil and replaced thermostat
Jan 14, 2018 at 10:48 PM
STEVE W.
  • 15,411 POSTS
This sounds like you have low engine coolant or the temperature blend door actuator stopped working but to but sure this video and guide can help us fix it.
https://youtu.be/SNRb6pSwYuU
and if the temperature blend door needs replacement here is a guide that can help with diagrams below to show you on your car.
This guide can help as well
https://www.2carpros.com/articles/car-heater-not-working
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Apr 23, 2021 at 3:53 AM
