Heartbeat noise from wheels when driving above 30 MPH?
35,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
NIKALKH
I've been hearing, anytime our car is driving above 30-35 MPH, this thumping or heartbeat noise that accelerates when you go faster i.e. driving on a freeway but is completely missing when going slower than the speed above. Three mechanics have listened to this noise and two have inspected the bottom of the car and all say they see nothing wrong. What can I suggest for them to re-look at based on this noise?
Jan 27, 2025 at 2:57 AM
NIKALKH
Video did not add. Please see attached.
Jan 27, 2025 at 3:01 AM
  • 110,248 POSTS
I listened to the video, but don't think I heard what you referred to. I did notice a click about three times but assume that is moving the recorder around. Is that correct?
On the other hand, often times a failing wheel bearing can cause this. Take notice if the sound changes when you are turning left or right and let me know what you find.
I will watch for your reply.
Jan 27, 2025 at 10:39 AM
NIKALKH
Hi Joe, here’s another video where the sound is clearer after about the 5 second mark. It doesn’t change when I move the wheel. Usually, bearings are more of a whistling noise.
Jan 27, 2025 at 11:16 AM
  • 110,248 POSTS
Bearings can be difficult at times. I listened to the video and only heard a click. It appears the phone is near the floor on the passenger side. Is it the click you are referring to?
Jan 27, 2025 at 11:47 AM
