Hearing a roaring sound while driving, but not when I press clutch in or move shifter to neutral
2012 CHEVROLET SONIC
111,247 MILES • 1.8L • 4 CYL • 2WD • MANUAL
NICKWHITE118
When driving and get to about 15 mph, I start hearing a roaring type sound from front end. The sound is almost like a rubbing sound, but not grinding. If I'm driving and press the clutch in or move the gear shifter to neutral the sound immediately goes away. There is no sound while idling.
I'm guessing it has to do with a bearing with the transmission or clutch. Any clue what I could be?
Nov 20, 2019 at 7:17 AM
STEVE W.
  • 15,345 POSTS
As the noise goes away when you press the clutch I would think it is a bearing inside the transmission. Likely on an output or carrier shaft as you say it doesn't make noise in neutral or at idle. The only way to be sure though would be to remove the transmission and pull it apart as there isn't really any way to look inside the transmission with it assembled.
Nov 21, 2019 at 12:19 AM
NICKWHITE118
Thanks Steve. I was assuming it was something of that caliber. Time to bite the bullet and take her in.
Appreciate the information.
Nov 21, 2019 at 3:11 AM
STEVE W.
  • 15,345 POSTS
You're welcome. Let us know what they find, please.
Nov 21, 2019 at 5:42 AM
