Should I replace both heads or can I just replace the driver's side?
150,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
NITRO170
Hello, I am working on the truck listed above with a 4.6 SOHC. What i am wondering is when I change the driver's side head would it be okay to not change the passenger side or would it be better to change both heads. I am replacing with remanufactured heads
Aug 26, 2024 at 7:04 AM
  • 55,766 POSTS
At 150,000 I would replace both cylinder heads, this will save you in the long run because intake and exhaust valves can leak causing issues. Let us know if you need anything else.
Aug 26, 2024 at 11:20 AM
NITRO170
Thank you for taking time to answer my question. I will change both heads!
Aug 26, 2024 at 11:56 AM
  • 55,766 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Aug 27, 2024 at 2:12 AM
