Headlights will not work
215,000 MILES • V8 • AWD • AUTOMATIC
TURKMH
We replaced the fuse and headlights. The low beams still do not work, but the high beams work when you hold the switch. Someone suggested replacing the multifunction switch. Any suggestions?
Jan 31, 2017 at 12:26 AM
HMAC300
  • 48,601 POSTS
check relay under hood first, then have a mechanic scan for codes as it may be a body module problem. if you choose to check multi-function switch the tan wire supplies power for headlight light/green goes out.
Jan 31, 2017 at 1:34 AM
