headlights were working and then shut off
200,000 MILES • 1.9L • 4 CYL • FWD • AUTOMATIC
JUSTBB
I fix the motor mounts in my car jump started it test drive it was fine for the first five minutes with the headlights were on I done did my dashboard lit up my high beams kicked on my headlights turned off but my tail lights work and I can't figure it out I checked my fuses on the car in their fine I check the bulbs in their fine and I check the wires that I can see but my dashboard flickers on and off and its been doing that for a couple years if you could or know anything about the problem it would be awesome this is a daily driver and I can't drive at night right now
Jan 21, 2014 at 4:31 AM
  • 31,937 POSTS
Which mount or mounts did you work on? I feel that you have disturbed one of the wiring harnesses.
Jan 25, 2014 at 8:39 AM
JUSTBB
I replace the front and back mount I checked all my wires they're all connected as far as I can figure it out its a bad ground and I don't know where to start
Jan 28, 2014 at 11:41 PM
  • 31,937 POSTS
Try running 3 new earths, battery to body, battery to engine and engine to body and see if that helps.
Jan 29, 2014 at 4:35 PM
JUSTBB
you're going to have to explain the earth are you talking about the ground ground the battery to the body in the ground it to the motor
Jan 29, 2014 at 10:32 PM
  • 31,937 POSTS
Yes that is correct, different country different terminology, so add extra cables from battery (-) to body, Engine and Engine to body.
Jan 31, 2014 at 4:23 AM
JUSTBB
alright I'll give that a shot any suggestions on what gauge wire I should use
Feb 4, 2014 at 11:19 PM
  • 31,937 POSTS
8mm or 10mm would be ok
Feb 11, 2014 at 4:21 PM
