Headlights went out
189,000 MILES • 0.5L • 6 CYL • 2WD • AUTOMATIC
VATACAMANA
Went down a dirt road got back on main road made a right turn and the headlights started flickering to a low dimming flash then went back to normal. Then made another right turn into driveway and they started to flicker like they were going out. Parked truck came back out to start and the truck and the lights will not turn on but the flood lights work and turn signals work, brake lights work, tail lights work but not the headlights.
Nov 20, 2018 at 9:49 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny,
I would suggest testing the headlight relay as it sounds possibly defective. I have attached a tutorial showing how to test wiring and Relays.The relay is located behind the right side of dash on the RPO relay Block #1. Hope this helps and thanks for using 2CarPros.
Danny-
Nov 20, 2018 at 3:00 PM
