Headlights turn on and off by themselves
140,000 MILES
JOHN BLY
The headlights turn on and off by themselves. so far have replaced headlight resistor.
Oct 13, 2016 at 10:25 AM
JOHN BLY
Low beams work, but will not stay on high by using signal switch.
Oct 13, 2016 at 11:04 AM
HMAC300
  • 48,601 POSTS
I assume fuses under hood have been checked. multi function switch is the more than likely the culprit you can test with headlight on. It might be tan wire at switch burned out.
Oct 14, 2016 at 5:29 AM
