Headlights shutting off and on while driving
109,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MR 350
While driving down the road my headlights cut off on my car, but eventually came back on. I noticed when it started doing that I was not able to use the headlight dimmer switch. it was not clicking any more. so it will not go from high to low or low to high. what could it be?
Apr 6, 2017 at 4:24 PM
SQM
  • 6,383 POSTS
It sounds like it could be a faulty headlight switch. It is possible to have corrosion on the connectors that is triggering the intermittent light on and off.
Check the connectors and make sure it is secured, free of corrosion or burnt pin(s).
Here is a helpful guide:
https://www.2carpros.com/articles/how-a-headlight-switch-works
Oct 27, 2021 at 2:35 PM
