headlights not working
172,000 MILES • 3.8L • 6 CYL • RWD • AUTOMATIC
EDDIE COCKERHAM
My parking lights work but not my headlights. the bulbs are good, wiring looks good, behind lights fuse under the hood is good 60 amp 6 c fuse 15 amp under dash is good. what next?
Sep 24, 2016 at 1:11 AM
HMAC300
  • 48,601 POSTS
there is also a circuit breaker under hood and a lamp module for the module. you will need to get it scanned to see if the module is working or not.
Sep 24, 2016 at 2:07 AM
EDDIE COCKERHAM
Where are the circuit breaker and lamp module located?
Sep 24, 2016 at 4:24 AM
EDDIE COCKERHAM
the circuit breaker from the looks of it is the 60 amp fuse on the modules and fuses on the firewall its fine. I looked at it and swapped it out with another one and no changes. looking on line now for a picture of lamp module.
Sep 24, 2016 at 4:29 AM
HMAC300
  • 48,601 POSTS
the lamp module may have to be programmed to your car if it does not work. i could not find a picture of it but it is left hand side of dash to left of steering column.
Sep 24, 2016 at 6:10 AM
HMAC300
  • 48,601 POSTS
digging around if you are handy you can fix yours if you look for what this guy did on you tube.
https://www.youtube.com/watch?v=ykJaW2DycCE
Sep 24, 2016 at 6:17 AM
