Headlights high low beam and DRL lights?
100,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
CLIF67
For the car listed above GT 40th Anniversary edition:
Headlights:
Are the bulbs used the same for high beam, low beam and DRLs? Also, do I need to install separate bulbs for each? i. e. Do I install one set of bulbs for low beam, another separate set for high beam, and another separate set for DRLs? Or do I need just one set that adjusts for each function?
Clif,
Apr 30, 2025 at 3:20 PM
  • 55,658 POSTS
Hello, this car has one bulb for each side that handles the headlight low/high and DRL functions. Here they are on Amazon:
https://amzn.to/432408P
Let us know if you need anything else.
May 1, 2025 at 3:54 AM
