Headlights on low beams are bright but when you turn on high beams all four lights are very dim.
Nov 14, 2017 at 6:24 AM
WRENCHTECH
✓Experienced Mechanic
Those lights all share a common ground. Being that the car is fiberglass, grounds are always a source of problems. Make sure you have a good ground both for the lights and for the frame to battery.
