Headlights
80,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
KANATAMAN
Have no low beam or high beam lights, high beams work when I pull back and hold the signal lever but nothing when switched to full time. Also no DRL. Fuses appear to be fine, power relay as well.
Sep 9, 2016 at 3:23 AM
HMAC300
  • 48,601 POSTS
check headlight relay by switching a like relay to see if that is problem and no corrosion on prongs of relay.then have it scanned for codes it may be a body module problem also check drl relay as it may be same cause.
Sep 9, 2016 at 5:04 AM
