Sure, it can be a couple of different problems but let's start with the easy stuff, please check fuse # 25 7.5 amp and fuse #56. Here is a guide to help and the fuse locations in the image below. If the fuses are okay, I would try swapping out the taillight relay. Here are the wiring diagrams for the switch as well so we can test through it.
Images (Click to enlarge)
Mar 4, 2025 at 4:01 AM
