Just brought a new drive side headlight plugged it in but the low beams will not come on just the highbeam and turn signal works. What's wrong?
Mar 30, 2016 at 11:20 AM
JOHNNYT73
✓Experienced Mechanic
just the low beam on the driverside? I would confirm that you bought the correct bulb for that vehicle.
Mar 30, 2016 at 12:10 PM
CASSANDRAGOFF
MEMBER
Yes the exact same one
Mar 30, 2016 at 12:40 PM
Check all fuses, I have seen where if the fuse is bad it will not allow the low beaks to come on. I have added a wiring schematic to help out. Please let me know what you find
