Headlights
2004 CHEVROLET CAVALIER
187,000 MILES
FRENCHMAN12503
I just put new head light bulbs in and I still have no low beams but have high beams according to the dash indicator. where do i go next to determine my problem. the fuses are good and the relay seems good also. could my issue be in the headlight switch in the steering column???
May 12, 2013 at 11:34 PM
HMAC300
  • 48,601 POSTS
recheck your fuses for corrosion then see if the bulb is getting power, if the bulb came from china throw it away and get a name brand bulb. then check your ground to that headlight.
May 12, 2013 at 11:51 PM
FRENCHMAN12503
I have power going to the bulb, no corrosion around the fuses or connections, good bulbs.
May 13, 2013 at 12:12 AM
HMAC300
  • 48,601 POSTS
check drl relay with another like relay and see if headlight works if not have it scanned to see if bcm is problem.
May 13, 2013 at 12:17 AM
