Headlights not working?
225,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JAMES ELI SUMRALL
It has no headlights. I've traced the power issue to the dimmer switch in the turn signal multifunction switch. There's a burnt wire at the top right connector and i need wiring diagrams of the circuitry please!
Apr 3, 2023 at 12:18 AM
  • 55,797 POSTS
Yep, here is a guide to help you test the connection and I have provided the head light wiring diagrams is the images below.
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Apr 3, 2023 at 7:01 AM
