Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Prizm
Exterior Light
Headlight
Not Working
Low beam headlights not working
2002 CHEVROLET PRIZM
200,000 MILES • 4 CYL • MANUAL
JAMES SNIPES
MEMBER
1 POST
The low beams do not work but the high beams do. The fuses are good and the bulbs are good.
Sep 8, 2019 at 3:38 AM
DANNY L
Experienced Mechanic
Hello, I'm Danny.
If the fuses are good you should check the headlamp relay next.Here is a tutorial showing how to test a relay:
I've attached a picture below of its location.Hope this helps and thanks for using 2CarPros.
Danny-
Image (Click to enlarge)
Sep 8, 2019 at 8:12 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
