headlights stay on when switch is off. I replaced switch but still stays on.
Jan 27, 2016 at 9:44 AM
JOHNNYT73
✓Experienced Mechanic
Check the relays in the junction box. Should have a high beam and low beam relay. I would disconnect the switch and see if the lights go out. leave it disconnected while you check the relays. The headlights are controlled by the BCM. Its not uncommon for these vehicles for it to fail leave the headlights on.
Jan 27, 2016 at 10:29 AM
PGSWITZER
MEMBER
I pulled the bcm out lights went out do I replace it
Jan 28, 2016 at 12:40 AM
HMAC300
uh ya
Jan 28, 2016 at 1:23 AM
JOHNNYT73
Yes, you can only get remanufactured from the dealer that need programmed.
