headlights
2001 PONTIAC MONTANA
200,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
ROBERTMURDEN
headlights will not go out with switch or auto feature. we have replaced the headlight switch. headlights will go out when breaker is removed. I have read that it may be the body control module. any ideas?
May 13, 2017 at 2:15 AM
HMAC300
  • 48,601 POSTS
the headlights go into the daytime running light module so that may be bad. any mechanic with a pro scanner can scan for codes to see if that is the problem. It probably is if everything else has been checked.
May 13, 2017 at 3:00 AM
