headlights not working properly
117,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
UNCLE GUMBYT
headlights come on when the ignition switch is off. sometimes you can turn ignition switch on and hit the dimmer switch on to bright and the lights will go off other times when the lights come with switch off the bright light indicator lights up. sometimes the lights will come on and go off by themselves.
Aug 26, 2020 at 6:15 AM
  • 110,248 POSTS
I have to be honest. It sounds like the switch may be bad. I need to know if you have daytime running lights or not to select the correct wiring schematic. I have already looked through both and there are differences with relays and so on.
Aug 26, 2020 at 7:21 AM
UNCLE GUMBYT
No I don't have daytime running lights, but I do have an alternator going bad. could that be part of the problem? Rich
Aug 27, 2020 at 9:27 PM
  • 110,248 POSTS
I have to be honest, low voltage can cause a lot of strange things to happen. Have you checked the alternator to see if it is providing enough voltage? Here is a link that shows how it's done:
It sounds more like a switch issue, but confirm the alternator is still doing enough.
Aug 28, 2020 at 8:31 AM
