Headlight not working
225,678 MILES • 5.6L • V8 • 4WD • AUTOMATIC
RICK ANDERSON2
I have one headlight that does not work along with my fog lights. I have replaced the bulb twice. I will work on high beam
Oct 4, 2019 at 5:20 AM
STEVE W.
  • 15,411 POSTS
Welcome to 2CarPros. Which light doesn't work? Passenger or drivers side? Do you mean the fog lights don't work or that when you use low beam they don't come on? The way the stock lamps normally work is that the fog lights only will work on low beam, then go off with the high beams. Does your truck have the automatic lamps or a manual switch? Does it have daytime running lights? The wiring and parts used are different so the answers will help track it down.
Mar 31, 2021 at 12:17 PM
