Can I get the headlight switch wiring diagram with colors?
320,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
THEBLUESCARECROW
  • 6 POSTS
I'm requiring a headlight switch wiring diagram with colors. The GN/WT feed got really hot, and I don't know why. The RD/WT got really hot too and I don't know what that wire feeds.
Nov 23, 2024 at 2:45 AM
  • 110,251 POSTS
I need some general information from you. First, is this a full-size van? Also, I need to know if you have daytime running lights (DRL) or not. The wiring schematics are different. See pic below.
Let me know if the wires you mentioned get hot only with the lights on as well.
See pic below.
Nov 23, 2024 at 1:01 PM
THEBLUESCARECROW
  • 6 POSTS
This is a full-size van. And too does it have daylight running lights. 1999 Dodge Ram Van Wagon B3500 is a complete description. It is in fact a full-size van. The wire that got hot is not the wire that feeds the headlight. I have ordered a new headlight switch. I will now figure this out on my own. Thanks!
Nov 23, 2024 at 1:51 PM
  • 110,251 POSTS
Nothing above indicated this is a B3500 van. It says wagon. People refer to caravans as wagons. Also, the B3500 came with both with and without DRL. If you provide that information, I can get you the schematic you need. If you decide you don't need them, that is fine, too.
Nov 23, 2024 at 2:01 PM
CARADIODOC
  • 34,415 POSTS
Hi Joe. Is there a full moon tonight? I read this question earlier but didn't post a reply because I too had no idea if it was a full-size van, a Power Wagon, or one of the other Wagons. Now I see it's a relatively uncommon full-size 3500 van. Had I taken a guess, that would have been my last choice. You should know it has daytime running lights. What's the matter with you, Joe. Afterall, those were never included on U.S. models unless the customer ordered it with them. That's why they're in the wiring diagrams under "export" version.
I just got a similar response. I provided much more information than requested, and now the fellow is mad because I didn't address his new problem or provide any details. I think I've had enough of this sitting in my freezing van so I can use Walmart's internet to help unappreciative people. I'm going home to my burned out house to sit in my warm garage. Hope your night goes better than mine.
Mr. Scarecrow, you should understand this site is free for you, but unlike on other forums where anyone can jump in to confuse the issue, here this becomes a private conversation between just two or three people. Joe helps more people than the rest of us combined. Any one of us will stick with you for days, weeks, even months if necessary until we reach a solution. You have no reason to post, "I'll fix it myself" when all Joe did was dare to ask the questions the rest of us were thinking. We don't even require a "Thank You" for trying to help, but we really do appreciate it when someone takes the time to post the final solution and how they reached it. That often helps other people researching the same problem. If that's too much to ask, you care less about helping others than we do.
Nov 23, 2024 at 2:20 PM
THEBLUESCARECROW
  • 6 POSTS
When did you ever see a Caravan with a 5.9L Engine? I get this same thing when I call for a pizza. Hi I'd like to order a personal cheese and sausage pizza, and the person says and what would you like on it. LOL
Oh, oh... looks like Mr. guilt trip has read his ugly head and the 3rd party darts are flying! When I listed my vehicle as... 1999 DODGE RAM WAGON 5.9L V8 2 WD AUTOMATIC 320,000 MILES and the first person comes back and asks... " is this a full-size van?", I know either his reading or comprehension skills are in question. Just out of curiosity I googled 1999 DODGE RAM WAGON. When I went to images... there were all the vans exactly like mine. Solution: I ordered a new Headlight Switch Standard DS346T from eBay and a new connector from O'Reilly's. Being without headlights, I don't have weeks or months. The first switch lasted 320,000 miles; I hope the next one lasts as long.
"but we really do appreciate it when someone takes the time to post the final solution". I did. I said... "I will now figure this out on my own". but you sure don't sound very appreciative.
Thank you!
Nov 24, 2024 at 3:55 AM
CARADIODOC
  • 34,415 POSTS
You are reading things I never typed. We know this is not a minivan by the 5.9L engine, but there was also a Power Wagon pickup truck. There's no justification for becoming angry for simply asking for clarification. I'd be grateful someone is trying to help. You need to understand that others can't see what you have. If asking simple questions bothers you, it sounds like you put too much effort into searching for a reason to be angry. Joe puts in so much effort to help people. He doesn't deserve an attitude. The information he asked for is not top secret. We also don't know if you're in the U.S., so it's proper to ask if you have daytime running lights. How angry would you be if Joe posted the wrong diagram? Seems to me Joe is trying extra hard to be as helpful as possible.
"Figuring it out on your own" is not a solution. There's a very good chance the new switch and terminals are all that's needed. We won't know for sure until the repair is completed. Many people will post the final solution months later or after another visitor with the same problem stumbles across the post and asks what the solution was.
Now please allow me to make another comment for the benefit of others researching this topic. Do not get angry when I mention the connector. I see you are going to replace it. The problem with most competent do-it-yourselfers is they do not understand the need to replace the overheated terminals. They find the defective switch but go only as far as replacing it. That will work for a while, but eventually the burned connector terminals will create excessive resistance which translates into heat. That heat migrates into the new switch's contacts and causes a repeat failure over time. The same thing happens quite often to ignition switches and a little less to dimmer switches. I've done this repair to dozens of '90s front-wheel-drive vehicles.
When it comes to replacing the connector, for us, time is money. To keep the customer's bill down, it is common to reuse the old connector after cutting out the melted cavities. Cut off at least four inches of the two old, overheated wires because solder won't adhere to those hardened sections. You need to go back to nice shiny copper. Solder on new sections of the same diameter, then use a pair of universal crimp-style terminals, but solder them too for the best connection. Plug those two terminals onto the switch individually.
If the thought of a chopped up connector body doesn't sit well with you, consider that the terminals in the new connector are usually the same style as the old ones. Instead of cutting and soldering all the wires, it's faster to pull the good terminals out of the old connector body, and pop them into the new one. The two that need to be replaced will already be on the new connector with a few inches of wire, so those are ready to splice.
Before splicing any wires, slide on pieces of heat-shrink tubing to seal the joints. Never use electrical tape as it will unravel into a gooey mess on a hot day. For this application, the heat-shrink tubing doesn't have to be the moisture-proof kind. The backs of the terminals are already exposed, so sealing out moisture from the splice has no advantage.
We'd still like a comment or two when the repair is completed so we know it has been handled.
Nov 24, 2024 at 8:48 AM
THEBLUESCARECROW
  • 6 POSTS
I did purchase a new switch from eBay. I ordered a new connector from O'Reilly's, but on second thought, I will abandon that $40+ charge and go with individual crimp-on terminals that are soldered and heat shrunk. For proper placement, I will keep a diagram in the glove box in my maintenance book. I would never use an old, overheated connector, as the terminals have been annealed and could never provide a proper connection and further, lead to yet another failure or maybe fire. The Van is 25 years old. I replaced the water pump, only to have it start leaking again. All the plastic pieces are breaking from age. I'm replacing the rotary switch that controls the rear fan motor. Luckily serendipity stepped-in and I found a nice heavy duty one on Amazon on the first try. All these automotive problems I'm having are caused by an external and invisible agency.
You see, I'm a retired Chicago Police Officer and a Paranormal Researcher of 46 years. Whenever I post things that they (aliens) don't like, they punish me; but I don't back down. Their technology is 600,000 years in advance of ours. We exist as Avatars in a 3D Movie, replete with CGI. Their control over us is invisible and extensive; people need to know what's really going on right under their noses. If you think I'm joking, I'm not. In 1978, one of their agents gave me an advanced infection in my left knee; very painful; all because I was telling everyone about a UFO that I saw. I've been working on a video all week and all these problems I'm having are, no doubt, because of that.
Thanks Tiny!
Nov 24, 2024 at 7:48 PM
CARADIODOC
  • 34,415 POSTS
I'm about four hours north of you, but I've been to Chicago many times for VCR schools and automotive training classes. I find driving in Chicago a lot easier than in my home city, at least that was the case 30 years ago.
You have the assessment of overheated connector terminals correct. Most people don't understand that, but a detailed explanation usually takes care of that. The same thing happens to heater fan speed switches when they're carrying the full motor current. Newer models do that with a tiny switch and a computer module. The most common place I've seen this is with ignition switches. They appear to cause the most trouble for people in the habit of turning the ignition switch on or off while the heater fan is set to one of the higher settings. Switching that much current on and off leads to a lot of arcing on the ignition switch contacts. There's usually three or four separate switches built into the ignition switches, so the engine will still crank and run. It's the "accessory" circuit that fails, with the heater fan, radio, and wipers as the most noticed dead systems.
I just finished 14 weeks of reshingling my garage roof and building a new, larger dormer over the garage door. A lot of that was done after dark. On one of those nights, I saw what I hope were satellites going from the northwest to the southeast. It was the right time of day for the sun to be reflecting off of them. First there were three in a row, and as I watched them, right after came a string of 20, all perfectly spaced and in a straight line. Took about two minutes to pass out of view. They were very bright and impossible to miss. I told a computer repairman friend about it, and he is 99 percent sure those were for Elon Musk's Starlink. I also saw something similar a few years ago, also early evening after dark. Those were five or six , again I'm assuming satellites, going from south to north. All followed the same path, but they were about 30 seconds apart, and not very bright. They didn't bother me, so I just waved "goodbye" to them.
Anyway, I have a different take on all our problems, from a preacher I heard on tv. His answer was, "this isn't heaven". Then it occurred to me, why bother looking forward to heaven if life is good here? Also, if tvs, vcrs, car radios, and cars don't break down, I'm not needed. If people don't misbehave, policemen aren't needed. Gotta be appreciative and find happiness where we can.
Please drop us a note when the repairs are completed, and let us know if there was anything unusual or difficult you ran into.
Nov 25, 2024 at 9:03 AM
THEBLUESCARECROW
  • 6 POSTS
I'm a High School Dropout. My school counselor sent me down to the Illinois Central Railroad HR. At a young age I exhibited a high mechanical aptitude. I wasn't even allowed to complete all the tests, the guy says you're hired; report to the Coach Yard at 7 am. That was the start of my electrical apprenticeship. My father was an electrician. Sometimes on the weekend he would come into my bedroom and say... "Don't you get lost." and I knew we had a job. I worked on the "Panama Limited" and "The City of New Orleans". From there they transferred me to the Markham Roundhouse where I worked on the Diesel Locomotives... Traction Motors, Main Generators, Control Wiring and ATS (automatic train stop). After that I wound up at the MU (multiple Unit) Shed, where I worked on the electric trains and their 1,200VDC overhead. My Journeyman Graduation Certificate was a reverser fork. LOL Wish I still had that. After that I applied to the Chicago Police Department. When I took the test, it apparently included GED questions. I passed; and a year later I was inducted into the Academy; that was 1970. I have since retired and I now live in Scottsdale, AZ.
More, If you ever see a UFO, run like hell. They mutilated this guy, just like the cattle, while he was alive. Thanks again for your input Tiny!
Nov 25, 2024 at 12:07 PM
CARADIODOC
  • 34,415 POSTS
I've often wanted to know how locomotives and helicopters work. Those will be goals for my next lifetime. Don't have enough time left in this one.
Nov 26, 2024 at 8:21 AM
THEBLUESCARECROW
  • 6 POSTS
The EMD SD90MAC Locomotive is a powerful unit, boasting 6,000 HP. That came along after me. A 16 cylinder diesel engine turns a main generator, which in turn powers the AC traction motors. The 3 phase main generator has two independent halves. One half of the generator powers 3 traction motors in the #1 front truck. The other half powers 3 more traction motors in the #2 rear truck. Back in the late 60's, the traction motors had carbon brushes. Since I was the apprentice, it was my job to replace the brushes. It was a dirty, filthy, greasy job. When I came out, it looked like I had been down there for a week; very nasty; usually done at the end of my shift.
As for Helicopters, I was trained in a Robinson which uses a vertically mounted Lycoming Engine. The pulley system uses 4 V-Belts for power transmission to the main rotor. A gearbox powers the rear tail rotor. The main rotor shaft has a Sprag Clutch which allows the main rotor to turn in one direction. Should the engine fail, the Sprag Clutch will allow the main rotor to turn freely, allowing for auto-rotational landings. The two main rotor blades are tin wrapped around Styrofoam. This doesn't provide much inertia during power off landings. When you flare, you had better be very close to the ground and don't bump the rear tail rotor. I've never flown a jet copter. The thing that really struck was the torque gauge. During throttle-up, you have to stay below 30%. The geared jet engine is so powerful that if you go any higher, it will twist the main rotor in two.
There I can send many more pictures and videos.
Thanks for writing.
Ps. Headlight Switch arriving Friday.
Nov 26, 2024 at 4:09 PM
