Headlights not working
153,000 MILES • 0.9L • 4 CYL • TURBO • 2WD • MANUAL
HAIRYGRAMPS
My dipped beams won't work.
High beams on even with switch to 0.
They go off when i switch to sidelight. I've changed switch, checked bulbs, fuses, ECU. everything seams okay, but zero volts at headlight plug. i need help tracing wires through engine bay. Also when checking lights fuse etc., the battery drains very quickly even just after charging up on charger.
Jan 4, 2020 at 9:16 PM
