low beam on the drivers side not working
123,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
DOCBATTLE
Driver side low beam headlight not working. Checked bulbs, fuses and relay, all seem okay. How can I check the wiring harness for broken connection?
Jan 10, 2017 at 9:05 PM
HMAC300
  • 48,601 POSTS
check wires with a test light or volt meter with headlight on at head light. it is a yellow wire and leads directly to fuse. test fuse with a test light or volt meter as well. it may be a connection problem.
Jan 10, 2017 at 10:55 PM
