Headlight -low beam, hi beam, and turn signal light
150,000 MILES • V6 • RWD • MANUAL
RE0468
The front driver side headlight and turn signal light will not work. All other lights are operational. I even turned on the hazard lights, however, nothing working on the left front side. I have checked all fuses in the module next to the battery and all are fine. Could it be a relay somewhere? Thanks you.
Oct 24, 2014 at 8:16 AM
WRENCHTECH
  • 20,760 POSTS
You need to test for power and ground at that light to determine which direction to go next depending on which one is missing.
Oct 24, 2014 at 1:08 PM
