Headlights conversion to either conventional 9006 or modern HID or LED
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
ARCHIE STEPHENSON
My SUV has HID lighting. Both are burnt out. any suggestions?
Sep 6, 2019 at 3:24 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It should be pretty straight forward replacement. Most all aftermarket HID kits are simply plug-n-play. If you remove the aftermarket HID you just might have an extra screw to remove that's used on a ground wire.After that just simply put a 9006 back in the factory socket/harness.
https://www.2carpros.com/articles/how-to-replace-a-headlight-bulb
Let me know if have an further questions.Hope this helps and thanks for using 2CarPros.
Danny-
Sep 6, 2019 at 10:55 AM
ARCHIE STEPHENSON
This is not an after market HID. It’s factory installed. It was available on the 2000 GMC Envoy as an option.
Sep 6, 2019 at 12:39 PM
DANNY L
  • 5,648 POSTS
Hello again.
Oh Okay, I've attached a few pictures below of the high beam, low beam, and headlight relays including their location. I've circled them in red.. Have you checked these to see if they are good/burned out? Here is another tutorial on how to test relays:
Let me know the outcome of you checking these. I can also provide you with a headlight wiring diagram if needed.Hope this helps and thanks again for using 2CarPros.
Danny-
Sep 8, 2019 at 6:45 AM
