Headlight Ground? headlamp relay begins to buzz?
179,600 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
VAPID28
When I turn my truck off the headlamp relay begins to buzz and I’ve cleaned all grounds for headlight and switch relays and continues with this issue.
Mar 13, 2023 at 11:28 AM
  • 55,743 POSTS
It could be an internally shorted headlamp bulb. Here are the headlight wiring diagrams so you can see how the system works and a guide on how to check the system.
Mar 14, 2023 at 5:21 AM
