headlight fuse keeps blowing
50,000 MILES • AUTOMATIC
MNELSON088
  • 22 POSTS
When I put a new one in it blows right away. any suggestions on where to start to try to find the short in it? or a route of which direction to go to find the short. thank you
Oct 8, 2021 at 7:14 AM
Good evening,
I attached a diagram for you to view. Please identify the fuse number that is failing so I can isolate the circuit for you.
I would start by disconnecting the headlights and see if the fuse still fails.
Once I know the fuse number, I can help you identify the failure. I attached some guides to help you with the checks. Let me know if you have any other questions.
Oct 8, 2021 at 8:49 AM
