Headlight electrical connector/port issue
167,000 MILES • 4 CYL • 4WD • AUTOMATIC
BLOOPBLEEPBLOP
My left headlight will turn on or go out sometimes when I hit bumps. Today it went out and stayed out. Upon further investigation I discovered the grey fastener clip on the headlight electrical port was able to be squeezed or pushed slightly and the light would come back on. Is this a wiring issue or do I need a new headlight connector? or something else?
Feb 4, 2019 at 7:46 AM
  • 110,251 POSTS
It sounds like the connector plug needs replaced. Often times, heat from the light will cause them to become loose. However, before replacing it, just confirm that there isn't a corrosion that just requires cleaning. Also, make sure the connector pins are not loose and pushing one of the wires out of the connector.
Feb 4, 2019 at 11:29 AM
BLOOPBLEEPBLOP
Thanks for the help Joe! I looked more closely at the connector and discovered that it was slightly burnt. I cut the wires and spliced a new connector (7 bucks) on in no time, headlight is working great now!
Feb 5, 2019 at 4:48 AM
  • 110,251 POSTS
You are very welcome, and I'm glad you got it fixed. Honestly, what is interesting about these types of connections is when they start to corrode or get loose due to age, power will arc within the connector. Any time you have an arc, it produces heat and makes things worse. Ultimately, the problem ends up with what you had. Just make sure where you spliced the wires together is properly insulated so it can't short.
Regardless, I'm glad it's working. Let us know if you have questions in the future.
Feb 5, 2019 at 10:45 AM
