Headlight assembly wiring diagram needed?
2015 LINCOLN MKS
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
DCD712
Issues with HID headlight driver's side. Replaced bulb and ballast. Fuse not blown; grounds appear to be good. Does anyone have a wiring diagram for the headlight assembly for the car listed above? Hard to find info on MKS.
Jul 27, 2023 at 11:01 PM
  • 110,241 POSTS
Have you checked for power to the light assembly? Do other functions on the left front work?
As far as the wiring schematic, it is two pages long. To make it readable for you, I had to cut each page in half. So, the first two pics below are from page 1 and pics 3 and 4 below are from pic 2. Additionally, I enlarged the left headlamp assembly only in pic 5 below.
Let me know if this helps.
Jul 28, 2023 at 12:59 PM
