Headlight assembly replacement
78,850 MILES • 3.3L • V6 • 2WD • AUTOMATIC
PILOTBILL
  • 88 POSTS
Hello, could you tell me step by step how to remove and replace a headlight assembly on the van listed above? Thank you.
Apr 12, 2019 at 10:50 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Here are the directions. The attached pictures correlate with the directions.
HEADLAMP ASSEMBLY
REMOVAL
picture 1
1. Position the parking lamp assembly aside.
1 Remove the screw.
2 Position the parking lamp assembly aside.
picture 2
2. Remove the parking lamp assembly.
1 Disconnect the connectors.
2 Remove the parking lamp assembly.
picture 3
3. Remove the screws.
NOTE: For the RH headlamp, position the relay box out of the way.
picture 4
4. Position the headlamp assembly aside.
1 Remove the bolt.
2 Remove the nuts.
3 Position the headlamp assembly aside.
picture 5
5. Remove the headlamp assembly.
2 Remove the headlamp assembly.
INSTALLATION
picture 6
picture 7
1. To install, reverse the removal procedure.
____________________________
Let me know if this is what you needed.
Apr 12, 2019 at 1:56 PM
