Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Cougar
Exterior Light
Headlight
Adjust
Headlight adjustment screws location needed
1987 MERCURY COUGAR
84,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JESSEL418
MEMBER
Where are the headlight adjustment screws located on my car listed above? Where can I find a diagram?
Feb 16, 2021 at 12:05 AM
Experienced Mechanic
They are going to be in the upper corners depending on which side you are looking at. Take a look at these pictures that will give more detail.
Here is a video on how to adjust these. Clearly your adjuster is in a different position but the process is the same.
https://youtu.be/c0757W_hZ6g
Let us know if you have other questions. Thanks
Images (Click to enlarge)
Feb 17, 2021 at 9:07 AM
JESSEL418
MEMBER
Feb 19, 2021 at 10:25 AM
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
