Headlight on driver side low beam will not work
114,569 MILES • 5.3L • V8 • 4WD • AUTOMATIC
STARTERUP3
I replaced bulb still will not work.
Nov 18, 2019 at 6:14 AM
  • 110,248 POSTS
Hi.
It has its own fuse. Have you checked that? I attached a pic from the wiring schematic showing fuse and location. Check that first and let me know what you find. Also, check for power in the yellow wire to the low beam. There should be 12v.
Nov 18, 2019 at 12:09 PM
HAVAS BORES
I am having the exact same issue. I thank you so much for making this video and possibly helping me to fix my issue with the low beam not working on the one side.
Dec 12, 2019 at 3:23 AM
  • 110,248 POSTS
I'm not sure which video you are referring to. Have you determined the issue with the low beam not working?
Dec 12, 2019 at 8:10 AM
