headlight not working
110,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
HEADLIGHT
Front Headlight (right side) does not work. Servo-engine for adjusting the beam also.
all fuzes are okay?
Oct 27, 2018 at 7:21 AM
  • 55,658 POSTS
Did you replace the bulb? If not here is a guide to help step by step with a diagrams below to show you how on your car also I have included the wiring diagrams so you can see how the system works.
https://youtu.be/LzdJeeeRvvs
If you have replaced the light use this guide to test to see where you lose power. Test for power at Fuse 26 and 16.
Cheers, Ken
Oct 28, 2018 at 10:40 AM
