headlight wiring diagram
78 MILES • 3.5L • V6 • AUTOMATIC
DGRAVES
Low beam passenger headlight went out, replaced bulb and ballast and the fuses and relays are good. Why is the light still not working?
Jan 13, 2019 at 4:46 AM
BMDOUBLE
  • 1,139 POSTS
One quick thing to try is to disconnect your battery for one minute and reconnect. The modules in these vehicles have protect circuits that will disable a particular circuit if there is an issue. A reset sometimes will restore operation so long as there is no more issues on said circuit.
Jan 13, 2019 at 8:00 AM
  • 55,711 POSTS
I agree with BMDOUBLE the smart junction box could be having troubles, if resetting it doesn't work let's confirm the failure by testing the power at the fuses. Here is a guide to help and the fuse locations with the headlight wiring diagrams so you can see how the system works:
If the smart junction box is bad you can replace it because it self initializes. Check out the diagrams (below) check for power at fuses # f19, f2 and f24. Please let us know what you find. We are interested to see what it is.
Jan 13, 2019 at 9:33 AM
PECCHE20
My driver side low beam went out. It is a hid system. I checked the fuses, replaced the hid bulb and it still does not work. I am assuming it is the ballast?... how do I remove the head light assembly to get to this?
Apr 26, 2020 at 4:17 AM (Merged)
MLDANIELS2000
  • 227 POSTS
Most likely bad ballast.
Removing headlight:
1.Remove the front bumper cover. For additional information, refer to BUMPERS .
2.Remove the headlamp assembly pin-type retainer.
3.Remove the 4 bolts and the headlamp assembly. Disconnect the electrical connectors.
4.To install, reverse the removal procedure
Removing bumper cover:
2.Remove the 6 pin-type retainers (3 each side).
3.Remove the 8 fender splash shield screws (4 each side).
4.Remove the 4 air deflector bolts.
5.If equipped, disconnect the fog lamp electrical connectors.
6.Remove the 5 bolts from the top of the radiator grille.
CITATIONMAN
Thanks for the instructions; worked like a charm. I paid 55 bucks apiece online (I did both even though only one was out). Could not have been more straightforward. The dealer wanted 150 bucks each and estimated 3 hours. I saved 500 bucks with DIY
OLIVE09
I currently have HID headlights and I want to know how to convert it to halogen or can I do that?
WRENCHTECH
  • 20,760 POSTS
That would be way more hassle that it would be worth. The car is wired for the HID modules and igniters.
OLIVE09
I cannot find a headlight assembly because mine is cracked so I thought it would be easier to convert it. Where do you suggest I look for an assembly at besides Ford?
WRENCHTECH
  • 20,760 POSTS
ford is the best place to get the parts.
