Headlight
80,000 MILES • 1.6L • 6 CYL • 4WD • AUTOMATIC
HUDSONK
My passenger side headlight was out (dim light), so I had the bulb replaced. That was not the problem; when you touch the bulb it comes on and off like there is a shortage somewhere. What can be the problem?
Sep 19, 2018 at 2:12 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Usually the cause of that problem is a faulty ground. Check the harness from the bulb connection and follow the black wire to its location. Check for a loose/burnt/corroded connection. I have attached a tutorial for you to view. Hope this helps and feel free to ask any questions.Thanks for using 2CarPros.
Danny-
Sep 19, 2018 at 8:45 AM
