headlamps only work on high beams
132,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
RWALKER50
i have problems with my high beams and low beam. it only work in high beam but not in lowbeam. the bulbs are good and switch good. help me please.
Dec 28, 2016 at 9:51 AM
STEVE W.
  • 15,418 POSTS
Take it to a shop with a good scan tool. Have them check for any headlamp codes. Clear the codes and see if the lights work. That has been a repair on many newer Chrysler products. If there are no codes and the bulbs test good then you will need to replace the integrated power module (main fuse box) under the hood as the headlamp controller is built into it.
Dec 28, 2016 at 4:57 PM
