HeadLamp Continously Stays On after removing the key from Ignition Switch
17,467 MILES • 1.4L • 4 CYL • TURBO • 2WD • MANUAL
NILESH_K
Hi Sir,
I am facing one problem in my ford Fiesta since last 2 days . Headlamps stay continuously on after removing the key for the ignition switch , due to which battery drained out completely which resulted in cranking problems.
My car was completely dead last evening when I went to start it . At last I had to jump start my car with the help of
one of my friends car . But again I am not sure whether the problem has completely solved on 100 % .
Please let me know the solution since my car is in warranty period .
Regards
Nilesh K
Mar 2, 2015 at 12:55 PM
HMAC300
  • 48,601 POSTS
hav it scanned for codes it may be body module or drl module problem. it's still under warranty so dealer can do for free
Mar 2, 2015 at 11:25 PM
NILESH_K
Hi Hmac,
Thank you for reverting .My dealer has checked for every thing & scanned the car as well,scanner didn't show any wrong codes . Eve then since I got my car last evening its working fine . But again I am worried that the same problem may occur in future . So please guide me accordingly & what precautions shall I take ?
Regards
Nilesh K
Mar 5, 2015 at 5:50 PM
HMAC300
  • 48,601 POSTS
if it happens again pull the fuses for headlights in under hood fuse boxl until you can get it to repeat more often an d hopefully by then i'll have amanual to trace the circuit.
Mar 5, 2015 at 11:01 PM
NILESH_K
Thank you for your valuable suggestions
Regards
Nilesh K
Mar 8, 2015 at 6:27 PM
