header tank
2008 NISSAN
12,000 MILES • 1.5L • TURBO • 2WD • MANUAL
YORKIE MAC
pressure in header tank cold air.
Feb 7, 2017 at 6:27 PM
  • 31,937 POSTS
do not quite understand your question can you tell me what the problem is? just tell me as best you can.
Feb 7, 2017 at 8:21 PM
YORKIE MAC
pressure in header tank coolant coming out off cap blowing cold air from heater.
Feb 7, 2017 at 8:26 PM
  • 31,937 POSTS
first thing to do is change the thermostat and bleed the cooling system, then get a cooling system pressure test done to look for any external leaks. there will be air trapped in the cooling system.has any work been done on the cooling system recently?
Feb 7, 2017 at 8:40 PM
YORKIE MAC
yes, this has all been done with the same outcome.
Feb 7, 2017 at 8:42 PM
  • 31,937 POSTS
okay, you need to get a head check done. this is a quick and simple chemical test to check for Co in the cooling system. also, make sure that the radiator is not blocked get it removed and core cleaned a back flush will not be enough and also flush and check the flow through the heater core as well.
Feb 7, 2017 at 8:57 PM
YORKIE MAC
thanks for all your help.
Feb 7, 2017 at 9:28 PM
  • 31,937 POSTS
ok, no problems, re post if you have further questions or problems
Feb 9, 2017 at 3:36 PM
