Header and catalytic converter connection
90,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
RHOOVER2
Just recently installed long tube headers which have a fixed three bolt flange on the collector. The high flow catalytic converters I am trying to install have a flared end with a free rotating flange with a slightly larger three bolt pattern although the pipes themselves are both 2-1/2". What is the best way to make this connection? Can I run a flange reducer in the flared end of the catalytic converter? If so is a seal or gasket required? Does this have to be welded?
Oct 23, 2018 at 1:13 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Just a quick question first. Is there a chance you can take a picture with your phone and upload it here? I would be happy to help after seeing. Hope this helps and thanks for using 2CarPros.
Danny-
Oct 23, 2018 at 8:42 PM
