head unit installation issue?
220,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BJIRINEC
wired all up and my A/C fan won't work, and my light freaks out. has stock sub.
Aug 17, 2024 at 7:24 PM
  • 110,251 POSTS
Have you first checked fuses for the blower motor? Also, which lights are acting odd? What are they doing?
First, check the fuses. I attached a pic below identifying three different ones for the blower motor to operate.
If they are all good and have power, I suspect you damaged a ground wire while working under the dash. If you look at pic 2 below, it shows a ground we need to check. It is G203. See pic for location.
Start with this and let me know what you find.
Aug 18, 2024 at 1:28 PM
