Head Torque sequence needed?
2015 MITSUBISHI LANCER
67,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
XLV
I cannot find the head bolt pattern for the 2015 lancer es non turbo or the torque sequence.
Jul 1, 2025 at 2:05 PM
MECHTRIX
  • 507 POSTS
Cylinder head bolt tightening Stages
1..tighten to 11 ft lb.
2..tighten to 26 ft lb.
3..90 degrees
4 then another 90 degrees.
Jul 1, 2025 at 4:42 PM
  • 55,399 POSTS
Here is the sequence. Check out the images (below). Let us know if you need anything else.
Sep 5, 2025 at 10:25 AM
