When driving at highway speed, the A/C stops working?
1,703,862 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
GREASE-MONKEY-BEAR
Okay, not sure. When the van is parked it has great air conditioning but when you get up to highway speed, it stops working. Replace the thermostat blower motor the Blower Motor Resistor did a flush. Then there is the heating problem, I have no heat at all. The next step is hooking up a set of gauges to get an a/c reading. Any help would be greatly appreciated. Thank you
Sep 28, 2022 at 9:05 AM
  • 55,616 POSTS
This sounds like either the engine is overheating and cutting the A/C off or you have an A/C compressor that is starting to go out. First, when the engine is cold remove the radiator cap and check the coolant level. If low please fill it up, this may fix the heater as well. Next you will need a gauge set to check the pressure when the engine is revved up to about 2,500 RPMs.
This guide can help you see what's going on:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
and
Please go over these guides and report back.
Sep 29, 2022 at 3:52 AM
GREASE-MONKEY-BEAR
Thank you, great information. just the overheated by the dashboard gauge it says it not overheating, I know that the gauge could be wrong, so I put my scan tool on it to read what the pc is reading and no show of overheating….
My game plan is to hook up my gauges to the van plus use a can of foaming a/c condenser coil cleaner, with a pressure washer.
Oct 5, 2022 at 5:43 AM
