Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Accord
Exterior Light
Headlight
Wiring
Low beam headlight do not work even though high beams works
1997 HONDA ACCORD
175,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JAMES KENNEDY2
MEMBER
1 POST
low beam headlight do not work even though high beams works. I change the fuses .
Mar 12, 2018 at 4:10 AM
Experienced Mechanic
There is a headlight relay that sounds like it is out. Here is the location of the relay and a test guide to help you confirm the issue:
Check out the diagrams (below).
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Images (Click to enlarge)
May 17, 2021 at 5:27 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
