High beams work low beam does not?
150,000 MILES • 0.5L • 4 CYL • 2WD • AUTOMATIC
LORI CUBIT
Jan 21, 2023 at 6:42 AM
  • 55,732 POSTS
First we need to check the 5 fuses that run the system, # 3, 9, 8, 24 in the interior fuse panel and fuse # 52 in the under-hood fuse panel. Here is a guide to help and I have included the fuse locations and the headlight wiring diagrams so you can see how the system works:
Check out the images (below). Please let us know what you find. We are interested to see what it is.
Jan 22, 2023 at 4:39 AM
