Headlights
150,000 MILES • 2.2L • 2WD • AUTOMATIC
DEANNA LYNCH HAMILTON
i changed the headlight assembly and now when i try to put high beams on it will not stay on unless i click it two or three times then they come on. my service light comes on and when i try to switch back to low beam my my inside high beam blue light stays on and so does the service light. I really cannot tell big difference between high and low.
Jan 2, 2018 at 1:48 PM
  • 55,758 POSTS
It sounds like the switch is defective did you use an ACDelco or GM part? If not this will be the problem. The inside circuitry of aftermarket switch are less than desirable or you have the wrong switch option.
Below is a guide to help others get the job done that visit this post.
Please let us know what you find.
Cheers, Ken
Jan 4, 2018 at 6:34 AM
