Head light bulb
234,000 MILES • 5.7L • V8 • RWD • AUTOMATIC
JOE1953
  • 811 POSTS
When I dim my light to low beam the bulb on the left side does not shine. what I have to do to replace the low beam bulb on the left side? Can you send me pictures on how to replace the low beam bulb on the left side?
Apr 24, 2016 at 1:08 PM
HMAC300
  • 48,601 POSTS
Check fuse and relay under hood fuse box first. It might have a pin under hood that you remove to remove headlight to replace it would be right out in open and easily spotted. Here is a link to a great article from this site with pictures on how to replace a headlight.
https://www.2carpros.com/articles/how-to-replace-a-headlight-bulb
Nov 17, 2017 at 3:53 AM
JOE1953
  • 811 POSTS
the bulb was burn out broke and water was inside the light (len) how water get into there?
HMAC300
  • 48,601 POSTS
the seal is broken in headlight get another one.
JOE1953
  • 811 POSTS
where do I get the seal for the headlight?
HMAC300
  • 48,601 POSTS
you have to buy the whole assembly they don't make the seals seperate
JOE1953
  • 811 POSTS
where do I get the hold assembly?
HMAC300
  • 48,601 POSTS
new, ebay or junkyard
JOE1953
  • 811 POSTS
how will I know I am getting a good assembly at the Junkyard?
  • 55,758 POSTS
